Business processes can only have one business process connection profile; however, activities within business process definitions may be assigned connection profiles that are different than the business process connection profile. This allows non-business process activities to interact with multiple repositories.
A single business process connection profile is used for all business process activities within a business process definition. This profile defines which repository the business process is associated with.
Note: Business process reporting can only appear in a single repository, and the business process can only be started from the repository defined in the business process connection profile.
Non-business process activities can be assigned different connection profiles depending on your needs. Learn how to define connection profiles for a workflow or business process definition on an activity-by-activity basis.
Example: Ben created a workflow that retrieves specific entries in Repository A, copies them, and attaches the copy to an entry in Repository B.  Ben can view the Business Process Details on entries in Repository B. See the
business process's connection profiles.
To configure a business process that interacts with multiple repositories
                     This documentation is specific to version 9.0. You can find the most up-to-date help files for the latest version at Current Online Laserfiche Product Help Files. For further help or feedback, please see the Laserfiche Support Site. |
                     © 2013 Laserfiche  |
